Interactive Registration Workflow in SCENE
With the new Interactive Registration features available in SCENE 2023.1 and later, FARO SCENE users can benefit from two key features, Interactive Registration and Hybrid Registration. Interactive scan registration provides an easy-to-use graphical user interface, allowing users to visualize how individual scans are linked together during the registration process and to manually control how those linkages are made. Hybrid registration allows cloud-to-cloud, targets, and survey control to be used together, separately or in various combinations.
Note: For projects already registered in SCENE versions before 2023.1, you will need to register again in SCENE 2023.1. Only then will you be able to use the Interactive Registration effectively.
Interactive Registration Workflow Guide
The following guide will step you through the use of Interactive Registration. Using either the automatic or manual methods for creating scan to scan connections and some helpful tips along the way.
FARO Academy
The FARO Academy course "FARO SCENE Interactive Registration"  has been developed to assist users on getting the most from these powerful and time saving new registration methods. The course covers the following topics:
  • Interactive Registration Introduction
  • Interactive Registration Tools
  • Coarse Registration
  • Automatic Fine Registration
  • Interactive Fine Registration
  • Hybrid Registration Adding Targets
  • New Cluster Behavior
  • Interactive Registration Issues
Click here to view the FARO SCENE Interactive Registration course on FARO Academy!
