2022
7.x
6.x
Measure From Point to Plane with SCENE
One of the most common measurements needed in FARO® Scene is to find the distance from some point to a surface or wall. For example, if an apartment complex is redesigning their parking lots they will need to know how far from the building a point on the curb may be.
Details
To create the measurement, you will need to first create the reference plane and point in the scan project. Then create a measurement between the two objects.
Create the Reference Plane
  1. Right-click a scan.
  2. In the context menu select View > Planar View
  3. In the Explore ribbon, click Selection and Select Rectangle from the context menu.
  4. Click and drag a rectangle on the reference plane to create a selection.
  5. Right-click the selection.
  6. Click Create Objects > Plane
  7. Click OK in the summary box.
Create the Point
  3. Click Mark Point in the Explore ribbon, or, if Mark Point is not visible, click Mark Point in the context menu under the mark option.
  4. Zoom in to the desired scan region and click the desired measurement point.
    Note: You can rename the point in the Structure View if desired.
Create a Measurement
  1. Click Measure Objects in the Measure context menu on the Explore ribbon.
  2. Click the point and plane in the Structure view.
  3. The measurement will appear in the scan image and in the Structure view.
    Note: Measurements can be taken between objects in different scans.
