2022
7.x
6.x
5.x
4.x
LT
Capture and Process
2026
2025
SmartInspect
Measure Q
As-Built
AutoCAD
Revit
Modeler
VirtuSurv
VirtuSurv 2019
VirtuSurv 2018
FARO Zone 3D
2026
2025
2022
FARO Zone 2D
2026
2025
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Visual Inspect
CAD Translator
Legacy Software
CAM2 Gage
WebShare Server and 2Go
Error-Code 19 Required XML Tags Not Found When Applying a V2C File
Install Icon
When you are updating your FARO® product license by applying the .V2C file you received in an email from FARO, you may see Error Code 19, Required XML tags not found.
This happens because your email client is changing the XML code in the .V2C file. If this happens to you, contact FARO Support and tell the Agent that you have received HASP error code 19. The Agent can help you in one of these ways:
  • Put the .V2C file on a FARO cloud storage account and provide you with a link so that you can download it directly.
  • Put the .V2C file in a .zip file and email it to you. When you receive the.zip file, extract it to your desktop.
Once you have an intact .V2C file, you can continue with the manual product license key update process.
