2022
7.x
6.x
5.x
4.x
LT
Capture and Process
2026
2025
SmartInspect
Measure Q
As-Built
AutoCAD
Revit
Modeler
VirtuSurv
VirtuSurv 2019
VirtuSurv 2018
FARO Zone 3D
2026
2025
2022
FARO Zone 2D
2026
2025
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Visual Inspect
CAD Translator
Legacy Software
CAM2 Gage
Error-Aksfridge Service With Parameters 1157 577 1 on HASP Driver Installation
Install Icon
Quick Steps
  1. In the system BIOS, change the Advanced Boot Options to Disable Driver Signature Enforcement.
  2. Install the HASP driver.
When installing the HASP driver, if an error message appears about a Sentinel Run-time Environment error for the aksfridge service with parameters 1157 577 1 and Status Code 48 5 733 577, the driver signature enforcement in the system Bios is enabled and causing an issue.
Sentinel Run-time Environment Error Message for the aksfridge Service
Prepare
Time to Complete 15 minutes
Skills Needed
  • Advanced understanding of the computer system BIOS
Prerequisites
  • The computer you use to run FARO software
  • Ability to access the BIOS on the computer
Details
  1. If the computer is running, shut it down.
  2. Start the computer and immediately start repetitively tapping the F8 control key to get to the system BIOS and the Advanced Boot Options.
    NOTE: On some systems, you must first press the F2 control key to get the Boot Menu, then press the F8 control key to reach Advanced Boot Options. If you cannot access the BIOS, contact your IT department.
  3. When the menu appears, use the Down Arrow key to scroll to Disable Driver Signature Enforcement.
  4. Press Enter and allow the boot process to continue.
  5. After your computer has completed the boot process and you have logged in, follow the instructions to uninstall and reinstall the Sentinel HASP driver to continue.
Troubleshooting
If the problem persists, contact FARO Support.
