2022
7.x
6.x
5.x
4.x
LT
Capture and Process
2026
2025
SmartInspect
Measure Q
As-Built
AutoCAD
Revit
Modeler
VirtuSurv
VirtuSurv 2019
VirtuSurv 2018
FARO Zone 3D
2026
2025
2022
FARO Zone 2D
2026
2025
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Legacy Software
CAM2 Gage
Error-Code 58 Invalid Recipient or Invalid XML Recipient Parameter
Install Icon
You might see error code 58 that comes from the Sentinel Admin Control Center that says Invalid Recipient or Invalid XML Recipient Parameter when you are setting up a network license server or when assigning a network license to a client computer not attached to the server. This error message occurs when the HASP license drivers used on the server and on client computers do not have the same version number. The HASP driver version number used on the server should match the version number used on the clients. When the version numbers match, you should not get this error message.
The latest FARO software always uses the latest HASP license driver. When client computers upgrade to a new FARO software release, the installer could upgrade the HASP driver to a new version. When FARO Software upgrades occur, check to see if the HASP driver version on the server matches the version on the clients. You may have to upgrade the server HASP license driver. Click here for details about checking the version of the installed HASP driver.
