Error-SafeNet Code 58 Invalid Recipient or Invalid XML Recipient Parameter
You might see error code 58 that comes from the Sentinel Admin Control Center that says Invalid Recipient or Invalid XML Recipient Parameter when you are setting up a network license server or when assigning a network license to a client computer not attached to the server. This error message occurs when the HASP license drivers used on the server and on client computers do not have the same version number. The HASP driver version number used on the server should match the version number used on the clients. When the version numbers match, you should not get this error message.
The latest FARO software always uses the latest HASP license driver. When client computers upgrade to a new FARO software release, the installer could upgrade the HASP driver to a new version. When FARO Software upgrades occur, check to see if the HASP driver version on the server matches the version on the clients. You may have to upgrade the server HASP license driver. Click here for details about checking the version of the installed HASP driver.
See Also
- Network License Server Setup to Share and Manage Multiple Software License Keys
- Download SafeNet Sentinel HASP License Driver and FARO Remote Update System (RUS)
- Assigning a Network License to a Client Computer Not Attached to the Server
Keywords
Detach, detaching, license, product key, dongle, link, move, transfer, softkey, soft key, soft lock, softlock, license server, product key activation, license activation, offline license activation, offline product key activation, activate product key
