2026
2025
SmartInspect
FARO Zone 3D
2026
2025
2022
FARO Zone 2D
2026
2025
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Software
InTouch
Licensing Manager
Silent Installation of FARO Software
In order to install software onto multiple machines, or at more convenient times, a batch file can be created to perform a silent installation (or uninstall where applicable). Included below is syntax information to help with the creation of these files. Only the software products listed below support silent installation.
Note: Silent mode is only supported when run manually through a Command Prompt with full Windows Administrator Privileges. Other Deployment Methods are not supported.
InTouch and Related FARO Applications
  • Silent mode is supported only for clean installations. To enable it, add the parameter “-q” or “--quiet" in a command line
  • If the installer is run when a version of the software is already installed, the installation window will be shown. In this case running the installer with “-q” or “--quiet" the setup will return error code 18
  • For the full uninstallation of InTouch and all applications installed through it:
  1. Make a copy of the folder: " C:\ProgramData\FARO Technologies\InTouch\Applications\InTouch\1.6.0\intouch.fulluninstallerapp  " to a temporary location, such as the Desktop.
  2. Run (as administrator):  " InTouch.FullUninstallerApp.exe -q " from the copied folder.
  • Silent installations will not reboot automatically if there is a pending windows update for example, so in that case the installation will fail. In order to proceed with the silent installation and allow the automatic reboot if needed the following argument must be passed:  " -r " or " --rebootIfNeeded "
InTouch
"[XX.XX.XX] InTouch Full bundle installer.exe" -q
Licensing Manager
"[XX.XX.XX] Licensing Manager Full bundle installer.exe" -q
"XXXX.XX_[XX] CAM2 Full bundle installer.exe" -q
CAM2 RPM
"XXXX.XX_[XX] RPM Full bundle installer.exe" -q
CAM2 SmartInspect
"[XX.XX.XX] CAM2 SmartInspect Full bundle installer.exe" -q
FARO Zone 2D/3D
"[XX.X.XXX] FARO Zone 2D Full bundle installer.exe" -q
"[XX.X.XXX] FARO Zone 3D Full bundle installer.exe" -q
Note: The FARO Zone 3D Full bundle installer is supplied as an .ISO file. The .ISO file must be "mounted" before installation is attempted.
FARO PDF Printer driver (optional) - Download
FARO_PDF2018_Pro.exe /auto
RevEng
"[XXXX.X.X] RevEng Full bundle installer.exe" -q
Install
SCENE_XXXX.X.X.XXXXX_Setup_SFX.exe /SP- /SILENT /NORESTART
  • You can use /VERYSILENT to suppress the progress dialog during installation. See https://jrsoftware.org/ishelp/index.php?topic=setupcmdline for additional settings.
  • For disabling the automatic update check you can add the additional argument /MERGETASKS="!updateCheckerTask". This deselects the option during installation.
  • To avoid the question for the opt in to the user experience program, set the registry key: HKEY_CURRENT_USER\SOFTWARE\FARO\SCENE\Settings\9.3\SendUsageData to 0 (after the installation). This key is specific to every user and every SCENE version. There is no machine-wide setting.
Uninstall
C:\Program Files\FARO\SCENE\unins000.exe can be run with the /SILENT or /VERYSILENT flags (source and documentation for those flags can be found at: https://jrsoftware.org/ishelp/index.php?topic=uninstcmdline)
As-Built for AutoCAD and As-Built for Revit
These installers try to install the FARO License Manager during the installation sequence, previously this prevented the ability to suppress all windows. An additional option “/SKIPLM” has been implemented for As-Built for AutoCAD and As-Built for Revit to skip the installation of the FARO License Manager.
However, As-Built will not function without the FARO License Manager and FARO License Service installed. Therefore, please first install FARO InTouch full bundle or the FARO Licensing Manager with the option “-q” as described in the InTouch section above.
Afterward, start the As-Built installer by using the command line switches "/verysilent /norestart /SKIPLM".
Example: As-Built_XXXX.X_for_AutoCAD_setup.exe /verysilent /norestart /skiplm
BuildIT
“path/of/the/installer.exe” /s /v/qn
(note the ‘space’ between “/s” and “/v/qn”)
FARO Zone - Legacy Versions
The following applies to FARO Zone versions not bundled with InTouch.
  • FARO Zone 2D - Versions 2025.4.0421 and earlier
  • FARO Zone 3D - Versions 2025.7.0707 and earlier
Prerequisites
FARO Zone installation requires the following prerequisites. All of the prerequisites listed below can be downloaded in a single .zip file at: https://farozonewebsupport.s3.us-east-1.amazonaws.com/FZ2024_Prerequisites.zip
Note: Licensing is provided by / with FARO InTouch, see Licensing Manager above.
Command line syntax:
#c++ redist 2015-2022
VC_redist.x64_2015_2022.exe /q
#Microsoft .NET 6.0.25
windowsdesktop-runtime-6.0.25-win-x64.exe /install /quiet /norestart
#MicrosoftEdgeWebView
MicrosoftEdgeWebView2RuntimeInstallerX64.exe /silent /install
FARO Zone 2D Installation
FZ2_XX_X_XXXX.exe /s /v/qn
FARO Zone 3D Installation
FZ3_XX_X_XXXX.exe /silent
