Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Error- 8-Axis Calibration Log File Cannot Be Obtained in FaroArm Manager or Unable to Apply 8-axis Compensation
When completing the calibration test for the 8-Axis system, an error appears stating that the calibration log file cannot be obtained or Unable to Apply 8-axis Compensation. To resolve this, try the following procedure.
Quick Steps
  1. Ensure any software communicating to the FaroArm and FaroArm Manager is closed.
  2. In Windows, go to the File Explorer.
    Input the following path:
    C:\ProgramData\FARO\FaroArmUsb
  3. Locate the following file (containing your 8-Axis serial number):
    TFX-XXX-XXX Turner Log.json
  4. Delete the file.
  5. Open FaroArm Manager.
  6. Try calibrating the 8-Axis again.
The calibration results should now save successfully. If you are still experiencing this issue, contact FARO Support.
