Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Legacy Gage
Bluetooth
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Error Codes for the USB FaroArm and ScanArm
The following article lists possible error codes for the USB based FaroArm® models. Before attempting to troubleshoot any error code, make sure the latest driver and firmware for your model is installed, as many times this may resolve the issue.
Error Codes
If you are unable to resolve the issue from information provided, create an Event Log Package as outlined in the following article: Event Log Package (Error Log) Creation for FaroArm. Send this Event Log Package file to FARO Support.
Error Codes: 7, 8, 9, 10, 12, 14, 15, 1000, 1010
An error between the FaroArm and the USB driver has occurred or the firmware and USB driver combination are not compatible with each other.
Error Code: 11
A connection error between the computer's USB port and FaroArm USB port has occurred.
Error Code: 13
An Ethernet connection failure has occurred between the FaroArm and the computer.
Error Code: 1023
The FaroArm has detected an unsupported attachment.
Error Code: 1025
An internal error in the FaroArm has occurred.
Error Code: 80000011
An internal Temperature Sensor Error between the FaroArm and the USB driver has occurred.
Error Code: 8000000f
An error between the FaroArm and the Laser Line Probe (LLP) has been detected.
For additional information and a workaround for Prizm LLP communication issues, see: Error Code: 8000000f Error Message with Prizm LLP
