Computer System Requirements for SCENE
Before you install the latest version of SCENE, check that your system meets the minimum system requirements.
System Requirements
The specifications below provide minimum, mid, and high configurations based on approximate scan volumes.
Hardware Minimum / ~10 Scans Mid / ~100 Scans*** High / ~1000 Scans
Dedicated Graphics Card Dedicated Nvidia*, OpenGL 4.3+, ≥4 GB VRAM + DirectX 11 Dedicated Nvidia*, OpenGL 4.3+, ≥8 GB VRAM + DirectX 11 Dedicated Nvidia*, OpenGL 4.3+, ≥32 GB VRAM + DirectX 11
Storage 512 GB SATA SSD 2 TB NVMe SSD 4 TB NVMe SSD
Internet Connection SCENE licensing requires an internet connection.
Main Memory (RAM) 32 GB RAM** 64 GB RAM** 128 GB RAM
Operating System Windows 11 (64‑bit) Windows 11 (64‑bit) Windows 11 (64‑bit)
Processor ≥ 4 physical cores @ 3 GHz ≥ 8 physical cores @ 3 GHz ≥ 32 physical cores @ 3 GHz
Video Screen 1920×1080 (4K not recommended) 1920×1080 (4K not recommended) 1920×1080 (4K not recommended)
VR Rendering SteamVR‑compatible 3D headset SteamVR‑compatible 3D headset SteamVR‑compatible 3D headset
Virtual Machine (VM) Supported Supported Supported
Remote Desktop Supported Supported Supported
* PanoCam Calibration is optimized for NVIDIA GPUs. Without an NVIDIA GPU, processing falls back to CPU and is slower.
** HDR full-resolution Focus scans require at least 64 GB RAM.
*** For Orbis scans, use 128 GB of RAM.
Earlier Versions
To download system requirements for earlier versions of SCENE, click one of these links.
Date Version Download
Aug 2018 2018
Nov 2017 7.1
July 2017 7.0
Oct 2016 6.2
Aug 2016 6.1
April 2016 6.0
Sept 2015 5.5.x
See Also
scene capture, scene process, scene LT, webshare cloud, webshare cloud 2go, release notes, readme, software requirements, computer requirements, computer specifications, install, installation, specs, specifications, hardware, minimum requirements, maximum requirements
