USB Driver for the FaroArm, ScanArm, and Gage
- Last updated
- Save as PDF
Your FaroArm®, ScanArm, Design ScanArm, or Gage works best with the latest driver. This article shows you how to download the latest or earlier drivers.
After servicing or recalibration of your device, plan to download and install the latest driver BEFORE you use the device. The factory provides the most recent hardware improvements when servicing your device, so using the latest driver may be required.
CAUTION: If you use software or hardware from a third-party vendor who makes FARO compatible products, verify the product is compatible with the latest USB FaroArm driver BEFORE you change the driver.
- If you are using the vendor recommended driver, do not change it.
- If you are not using the recommended driver and the vendor's product is not compatible with the latest USB FaroArm driver, see the earlier drivers list in this article to find the driver the vendor recommends.
Latest Driver
- Download the latest FaroArm driver:
Version: 6.12.102
Release Date: 14 Apr 2026
Download
- View the What's New article to learn what has changed in the latest version.
- Go to Upgrade the FaroArm USB driver installation instructions.
System Requirements
| Processor | Intel or AMD |
| Operating System | Microsoft Windows 11 (64Bit) For a complete list of Windows support by driver version see: Microsoft Windows Operating Systems That Are Compatible with the USB FaroArm Driver |
Earlier Drivers
Click here for details about which versions of Microsoft Windows supports different driver versions and computer processors.
Hardware Support Notes:
The latest driver version is compatible with all USB FaroArm and ScanArm models*. Model specific, minimum required versions are listed below.
| Model/Device | Minimum Required Driver |
6.11.14 |
6.7.63 |
6.3.0.11 |
6.2.0.26 |
6.0.0.63 |
5.8.5.2 |
5.8.4.5 |
* Provided the FaroArm firmware is up-to-date.
**8-Axis support for the Edge requires an authorized firmware upgrade, contact your local sales representative for details
See Also
- Find the FaroArm USB driver version installed on computer
- FaroArm Manager Introduction and General Instructions
- Firmware Download and Installation Instructions for the Quantum S and Quantum M
- Driver, firmware, and kiosk software download for FaroArm Edge
- Firmware download for Laser Line Probe (LLP)
- Windows operating systems compatibility with FARO software
- Upgrade the drivers on a Serial FaroArm
- Warranty Benefits and Management
Keywords
faro usb driver, faro arm driver, reinstalling, reinstall, re-install, updating, update, LLP driver, Laser Line Probe driver, OS, operating system, latest driver, current driver, newest driver, new driver, earlier driver, past driver, old driver, dsa
