2022
7.x
6.x
3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
Focus3D X
Focus3D X HDR
Focus3D S
Software Developers Kit (SDK) for the Laser Scanner
The FARO LS SDK is no longer being developed; the final release was on February 16, 2022. Support is no longer being provided for the FARO LS SDK.
FARO provides the SCENE API and LS Web API to contracted partners which enables application engineers to create custom software to read, write and change SCENE files and to control FARO Focus laser scanners.
The FARO® Laser Scanner and SCENE have a Software Developers Kit (SDK) that enable application engineers to create custom programs to control the scanner and read, write, and change SCENE files. The SDK is available in a zip file for those approved to receive the toolkits.
  • LS SDK - This SDK enables software developers to create applications that open SCENE data files in third-party software, such as AutoDesk Recap. It is not intended for creating applications that extend functionality to control the FARO® Laser Scanner Focus or read scans into custom or proprietary software. This SDK is available in the developer zip file and is also available for separate download.  Download it here.
  • LS SDK_DEV - This SDK allows programs to control the laser scanner. The SDK is backwardly compatible, maintaining existing function and libraries when new functions and libraries are added. This ensures programs written for Legacy scanner models continue to function as expected.
  • SDK Developer Manual -  This manual shows software developers how to install, license, and use FARO Laser Scanner (LS) COM interfaces to build custom software. The manual is available in the zip file and is also available for separate download.  Download it here.
    WARNING: LS SDK and LS SDK_DEV are still currently valid, but they will not be developed further and will be discontinued in the future.
Getting the SDK Files
To get the SDK files, contact your regional FARO Support. The Agent will help you fill out the non-disclosure form and submit it for approval to FARO product management. If the project is approved, an Agent will send the link to the zip file containing the files listed previously and documentation information.
Getting Technical Support for the SDK
To get support for the SDK, contact FARO Support Europe. Please be advised that those requesting support should be experienced in application development and understand how to work with functions, libraries, and data structures.
Note: Due to a new revision of FARO FocusS and FocusM scanners, we will introduce a new file format starting in March 2019.
FARO SCENE SDK versions released prior to 2019.0.0.1457 cannot import scans produced using FARO FocusS and FocusM scanners (revision B, distributed after March 2019) with firmware version 6.4.0 or higher.
Supported Programming Languages
  • Visual Basic
  • C# for .NET-- You can use .NET Visual Basic to access the C# SDK
  • C++ for Visual Studio 2008
  • Windows C++
Supported Operating Systems
  • 64-bit—Microsoft Windows 7, 8.x, and 10
Note: Linux is not supported.
