2022
7.x
6.x
5.x
4.x
2026
2025
SmartInspect
Measure Q
Measure X
As-Built
AutoCAD
Revit
Modeler
VirtuSurv
VirtuSurv 2019
VirtuSurv 2018
FARO Zone 3D
2026
2025
2022
FARO Zone 2D
2026
2025
2022
BuildIT
Construction
Metrology
Projector
RevEng
RevEng
Visual Inspect
CAD Translator
FARO Licensing Manager - Unexpected Behavior When Password is Required
This article explains how to proceed if the FARO Licensing Manager behaves unexpectedly when a password is required to access Sentinel Admin Control Center.
Licensing Manager displays a loading screen
When launching the FARO® Licensing Manager application, the user can be presented with an endless "loading" screen, and the license information is not displayed. This issue can only happen on Licensing Manager/service versions < 2.1.45.
To solve the problem, please update the Licensing Manager and service to the latest version available.
Please check the Release Notes v.2.1.45 for more information.
If the manager shows an endless loading screen it’s possible that ACC has been password protected by the user.
To confirm this, please open http://localhost:1947/_int_/config.html on the affected machine and check if any of the options highlighted are selected:
In latest HASP versions it is mandatory to choose a password to select either one of those options.
Error when password is required
Older versions of the Licensing Manger may show this when the Sentinel Admin Control Center has been password protected by the user:
How to Fix
By updating the Licensing Manager to the latest version available, you will be able to unblock the application and use it with some minor limitations. In alternative, please find here information on how to Remove the password protection from Sentinel ACC.
