Download and Install the SafeNet Sentinel HASP License Driver and FARO Remote Update System (RUS)
The HASP driver and RUS enable FARO software licensing. Both are installed when you install FARO software. If you do not use an internet connection with your FARO software, are creating a license server, or are having issues with the automated internet-based license activation inside FARO software you may need to manually install the latest versions of the HASP driver and RUS.
- The HASP driver is the central component of the FARO software license processing. It also provides access to the SafeNet Sentinel Admin Control Center where you can view, administer, and manage FARO software licenses.
- RUS enables you to manually activate or update FARO software licenses.
Both the HASP driver and RUS can be used on a stand-alone computer or on a network license server and its client computers.
Always make sure you use the latest versions of the HASP driver and RUS. They are backwards compatible, so you need not be concerned about using the latest versions with older FARO software. Using the latest versions helps you avoid licensing issues.
Download HASP/RUS Files
Use the links below to download the latest versions of the HASP driver and RUS.
Note: FARO BuildIT products use a different HASP driver from other FARO products.
- SafeNet Sentinel HASP License Driver
Version number: 8.13
Alternate Download Link - SafeNet Sentinel HASP License Driver (FARO BuildIT products only)
Alternate Download Link - FARO RUS
Version number: 7.9.23583.60000
Verify the HASP Version Number
- On the FARO software PC, open an Internet browser and go to http://localhost:1947. The Sentinel Admin Control Center appears.
- Click Diagnostics.
- At the bottom in the Run-time section, note the number next to Run-time Installer. This is the HASP license driver version number.
- The latest HASP version number is 8.13.
- The latest HASP version number for BUILD IT users is 8.13.
Verify the RUS Version Number
- Locate and right-click FaroRUS.exe.
- Click Properties. The FaroRUS.exe Properties window appears.
- Click the Details tab.
- Note the File version number.
- The latest RUS version number is 7.9.23583.60000.
Uninstall the Old HASP Driver
- Extract the haspdinst<VerNum-Date>.zip file you downloaded to the root of your C:\ drive. Do not put it in a sub-folder.
- Exit FARO software and remove any dongles or portlocks connected to your PC.
- Click the Windows Start menu. In the search field type cmd and press Enter. The Command Prompt window appears.
- If the command prompt is pointing to C:\>, skip this step. If not, at the prompt type one of these commands and press Enter.
- If your prompt is pointing to a drive other than C, type c: and press Enter.
- If your prompt is pointing to C but is not at the root, type cd\ and press Enter.
- At the C:\> prompt, type haspdinst.exe -kp -r -fr -v -purge to uninstall the current HASP driver.
A status window appears while this operation runs. When it is done, the Operation successfully completed windows appears.
- Reboot your computer.
Install the New HASP Driver
- Ensure you have administrator privileges on your computer. If you do not, contact your IT department.
- Turn off all anti-virus and firewall software, or contact your IT department and ask that an exception be created for .dll files located at C:\Program Files (x86)\Common Files\Aladdin Shared\HASP.
- Repeat steps 3 and 4 above to get the Command Prompt window and the C:\> prompt.
- A t the C:\> prompt, type haspdinst.exe -i -fi -kp -fss to install the latest driver.
- A status window appears while this operation runs. When it is done, the Operation successfully completed windows appears.
- Open an Internet browser and go to http://localhost:1947, if you see the SafeNet Sentinel Admin Control Center, installation was successful. Verify that your version is now current.
Uninstall the Old RUS
To uninstall RUS, find FaroRUS.exe and delete or rename it. The file's location is different depending on the type of computer you are using: Stand-alone computer, client computer, or license server.
For a stand-alone computer or client computer
The RUS file is stored in the root of the folder where the FARO Software you are running is stored. If you accepted the file storage defaults when you installed your FARO software, the RUS file is in one of these folders.
- C:\Program Files\FARO\<FAROSoftwareName>
- C:\Program Files (x86)\FARO\<FAROSoftwareName>
For a license server
The RUS file could be stored anywhere. If you have followed the instructions for creating a license server, the file is stored in the C:\FaroRUS folder. If not, you can search for it.
Install the New RUS
- Copy the new FaroRUS<VersionNumber>-<date>.zip file you downloaded at the top of this article to the folder where you found the old RUS.
- Extract FaroRUS.exe to the same location as the old RUS file.
- Test that you can access the RUS.
- On a standalone computer or client computer--From the Windows Start menu click All Programs > FARO > <FAROSoftwareName> > FARO RUS or FARO Remote Update System. This makes sure that the Start menu link to the RUS works correctly.
- On a license server--Double-click FaroRUS.exe to run it.
- When you see the RUS window, installation was successful. Verify that your version is now current.
See Also
- Error-SafeNet Starting the Sentinel License Manager Service
- Error-SafeNet Code 35845 Sentinel HASP License Driver
- TCP/UDP Port Used by the Sentinel HASP Driver and FARO Licensing System
- Network License Server Setup to Share and Manage Multiple Software License Keys
M10, measure 10, portlock, HL, upgrade, software key, license key, activation, portlock, M10, Safenet, product key, dongle, SL, HL, soft lock, softlock, hard lock. hardlock, thumb drive, USB drive, flash drive, HASP Driver, HASP Driver Install
