Release Notes for Licensing Manager
This article lists the Release Notes for each version of the Licensing Manager. The current version release notes are displayed at the top of the article. Previous revisions (if available) are contained in expanding sections below.
Navigating this article:
- Use the Table of Contents block in the upper right hand of this article to jump to a release
- You can expand a version section by clicking the + button
- To search all versions, click the Expand All Versions button and then use the Ctrl+f search feature in your browser. Sections must be “expanded” to be searched
Licensing Manager Release Notes – Version 2.1.195
What's New:
- .NET 10 Upgrade for Licensing Manager & HASP Driver - Upgraded Licensing Manager, Licensing Service, and the HASP Driver deployment package to .NET 10, removing the dependency on .NET 9.
- Streamlined License Filtering in Licensing Manager - Simplified the main screen filter controls to easily view licenses by state (Active / Expired) and host type (Local / Network), with user filter preferences now automatically persisting across application restarts and updates.
Fixed Issue
- Sentinel Remote Access Configuration Sync - Resolved an issue where remote client access settings modified in the Sentinel Admin Center were not updating or reflecting correctly upon refresh in Licensing Manager application.
Licensing Manager Release Notes – Version 2.1.184
Fixed Issues
Licensing Initialization Hang Without Internet Connection.
Summary: Resolved an issue where host applications would freeze or take several minutes to initialize licensing when running offline
Key Changes: Addressed the offline timeout during license manager startup. Initialization now completes promptly without freezing the host software
Disable and Persist the "Remember my choice" Checkbox State
Summary: Updated the default state and persistence behavior of the license selection preference in Licensing Manager
Key Changes: The "Remember my choice" checkbox is now unchecked (disabled) by default. When enabled by the user, the selection persists across application restarts, system reboots, and application updates/reinstallations
Licensing Manager Release Notes – Version 2.1.163
What's New:
- The Licensing Manager app now displays connected empty dongles on the "Manage Licenses" home screen, making it easier to view, manage, and update unprogrammed hardware keys
Licensing Manager Release Notes – Version 2.1.160
What's New:
- Licensing Manager updated to Sentinel LDK 10.32. The Licensing Manager app and service are now installing the HASP driver v10.32 and vendor libraries v10.31
Fixed Issues:
- Minor issue fixed in the Licensing Manager notifications, for when no updates are available. The second try to update a license with no updates, would return an error notification instead of a notification for “No updates found”
Licensing Manager Release Notes – Version 2.1.150
What's New:
- “Remember my choice” Is an option of the License Selection Screen that allows customers to select and save the license they want to use to run software applications (below). In the present release we made this option selected by default, improving customer experience
Licensing Manager Release Notes – Version 2.1.145
Fixed Issues:
- "Start Service with Admin Privileges" button wasn't working correctly
For non-admin users, clicking the "Start Service with Admin Privileges" button in the LM UI did nothing. The fix ensures the button now correctly starts the service as admin when it's stopped - Unable to auto-start Licensing Service for non-admin users
Non-admin users couldn't start the Licensing Service at all. The root cause was a missingInTouchProxyfolder in the installation directory. - Signature of the IntouchProxy.exe.
After installing LM v2.1.112, there were two copies ofInTouchProxy.exein different locations — only one was signed. The root cause was a ghost reference to the InTouchProxy project in the solution, causing a duplicate copy. The fix removed the stale reference so only oneInTouchProxy.exeexists, and it is now properly signed.
Licensing Manager Release Notes – Version 2.1.142
What’s New:
- The Licensing Manager app has a desktop icon and can be found in the Windows' start menu. With this version a new desktop icon for the Licensing manager is created and the app can also be found in the Windows' start menu
Licensing Manager Release Notes – Version 2.1.140
Fixed Issues:
- The License Selection window is showing “no available licenses ” multiple times, at BuildIT software startup, when the user had only one license available. The problem has been fixed in the current release
Licensing Manager Release Notes – Version 2.1.138
What’s New:
- The Licensing Manager app was incorrectly showing the Virtual Access option as enabled for dongles. Since Hardlock licenses cannot be used on virtual machines, this option should be disabled for dongles. This has been fixed in this release
- The logos displayed in the Licensing Manager app and the Licensing Client have been updated to the new Ametek logo for FARO Creaform and FARO Insight, as shown in the images above and below, respectively
- The Licensing manager app had some inconsistencies in the Japanese language which have been reviewed and fixed
- The Licensing Manager app also had translations missing in the offline update workflow. The correct translations were added in the current version
Licensing Manager Release Notes – Version 2.1.126
Fixed Issues:
The Licensing Manager app was wrongly using the FARO Creaform logo. That has been fixed and it will continue to use the FARO logo, until the definitive solution is implemented.
Licensing Manager Release Notes – Version 2.1.124
What’s new:
Identification on the Licensing Manager of cloned licenses - strings translation. Even though this improvement was released on version 2.1.122, the related strings in English were not being translated into the different support languages. The necessary translations have been added to version 2.1.124.
Licensing Manager Release Notes – Version 2.1.122
What’s new:
Identification on the Licensing Manager of cloned licenses.
A cloned license is a legitimate software license that has been duplicated unintentionally or intentionally by copying the entire system image of a machine—including the installed software and its license—to one or more other machines (more information here). In other words, the license itself was valid when it was originally issued, but it becomes invalid when it appears to exist on multiple machines due to system cloning.To make it easier to understand if this is the status of your license, you can check for the “Cloned” label in the Licensing Manager home page.
The same identification is visible when you run a given software application and see the Licensing Selection Screen:
Licensing Manager Release Notes – Version 2.1.120
Fixed Issues:
- In some cases the installation/update of the Licensing Service would succeed even if HASP Driver wasn’t installed/updated as expected. In this version we are validating that the expected version of the HASP driver is installed, if not, the process will visually show the failure
- The displayed of an error message in the License Activation window of the Licensing Manager app, was not being displayed correctly: “The key provided could not be activated.” It was particularly evident in the German language:
The message is fully displayed in the current version:
Licensing Manager Release Notes – Version 2.1.116
Improvements:
- To make sure we don’t generate runtimes that we don’t use, we reviewed it and now only win-x64 runtimes are used
- The licensing manager and service have been improved to only use HTTPS requests under "faro-cloud.com"
Licensing Manager Release Notes – Version 2.1.112
HASP Driver version: 10.12
Fixed Issues:
- For long local machine names, the Licensing Manager wasn’t showing the full name on the Network Configuration tab. Plus, in this situation, the options to update the license online or offline were disabled. This problem has been fixed with the present release
- Code signing for the licensing manager has been updated
Licensing Manager Release Notes – Version 2.1.99
Fixed Issues:
- The Licensing manager was not showing the license product(s) name(s) on dongles
With version 2.1.99 of the Licensing Manager, this problem has been fixed. To see the product name displayed correctly, the user should update the Licensing Manager to this version, using the Intouch app or the update option of the installer.
Licensing Manager Release Notes – Version 2.1.97
What’s new:
- Each license listed on the Licensing Manager now has a button that redirects to the Web Portal License Information page. With that, the user can more easily find detailed information about the license
- The “My selected licenses” screen was showing the software names for which the license has been selected in a very confusing way. That has been simplified and is now more perceptible to the user, which license has been selected for which product
- The “Transferable” option on the Licensing Manager filter shouldn’t be displayed, so it has been removed
Fixed Issues:
- License Selection screen was showing duplicated entries
- The Licensing Manager wasn’t sorting the list of licenses available correctly. That has been fixed. The sort is done by License ID, but if a dongle is plugged in, it appears listed first
Licensing Manager Release Notes – Version 2.1.82
What’s new:
- Licensing Manager updated to Sentinel LDK 10.12
- Changed the location of support data for licensing. The new location is C:\ProgramData\FARO Technologies\Logs
Fixed Issues:
- License Selection screen takes too long to open when there is no internet connection. This issue was found internally and has been fixed in the present version
- Licensing Selection screen shows an infinite loading. Sometimes the licensing selection screen wouldn’t load the available licenses, instead, it would display an infinite loading. The problem has been fixed
- When the support file reaches 100MB limit no more information is written. This limitation has been overcome in the present version and the support data continues to be written in another document
Licensing Manager Release Notes – Version 2.1.67
What’s new:
Licensing Manager updated to Sentinel LDK 10.11
Licensing Manager Release Notes – Version 2.1.63
Fixed Issues:
Fixed strings in the German language
The Licensing Manager didn’t start if HTTP(S)_PROXY environment variables were set. This problem was reported on a customer’s computer, but the problem has been fixed with version 2.1.63 of the licensing manager/service and licensing client
Licensing Manager Release Notes – Version 2.1.45
What’s new:
- A Product Key with spaces is now accepted by the Licensing Manager. When trying to activate a Product key on the licensing manager, sometimes an extra space was included as a result of copy-paste. This would make the key invalid for activation. In this new version any space introduced is excluded and the key can be successfully activated.
Fixed Issues:
- Licensing Manager Stuck on Loading Screen - On launch of the Licensing Manager application, the user was sometimes stuck on an endless "loading" screen most probably because the Sentinel Admin Control Center had been password protected.
In this new version, the endless loading screen has been fixed and the Licensing Manager works properly, with the following reservations:- The “Configuration” window reflects the password-protected state. The user must follow the on-screen instructions to remove the password and be able to use this page to configure the sharing of network licenses.
- On the “Licenses” screen, for network licenses, the number of seats will not be displayed (until the password protection is removed).
Licensing Manager Release Notes – Version 2.1.31
Fixed Issues:
- HASP session shouldn't expire while the license is in use - some As-Built Customers noticed that the license selection screen prompted quite often while they were using the software. That problem has been fixed.
- Some strings on the Licensing Manager were not translated - In this version those strings have been translated into the supported languages.
Licensing Manager Release Notes – Version 2.1.29
What’s new:
- Settings panel on the Licensing Manager - Forget my license selection - The “Remember my choice” option of the License Selection Screen allows customers to select and save the license they want to use to run FARO software. The licensing manager has now a settings panel, with a button to see “My selected licenses”.
Clicking on the button opens the “My Selected Licenses” screen, which allows customers to delete the saved license selection for a given software product.
- Scroll bar added to the Licensing Manager Offline activation - In some languages the content of the offline activation page was not being displayed as expected. This has been improved by adding a scroll bar to the page.
- Read notifications don’t count for the notifications’ icon color - In the Licensing Manager a new notification may change the color of the notification’s icon (displayed on the top right corner of the application). If a customer opens a notification, that notification has been read and therefore it doesn’t count anymore for the notifications' icon color.
Fixed Issues:
- Wrong product logged in for FARO Zone 3D 2024 Expert - If a customer had a FARO Zone 3D 2024 Expert license when opening the software we would only get FARO Zone 3D 2024. This problem is now fixed.
What’s new:
- New HASP version - With this release of the Licensing Manager, the version of the HASP driver installed is 9.14 and the vendor libraries are 9.13.
- .NET update - The version of .NET has been updated to 8.0 (version 8.0.3).
- License Selection Screen - The readability of the License Selection screen has been improved, providing clearer information to the end user:
E.g. As-Built AutoCAD:
- When a customer runs As-Built AutoCAD, the licensing selection screen will be displayed.
- The License Selection screen will not be displayed if there is only one valid license. In this case, the licensing client will log in automatically on that license.
- If the License Selection screen opens, it will start loading the available licenses:
- The License Selection screen will:
- Show valid licenses for that product (if there are more than 1 available)
- Show valid licenses for that product that expired, with the option to update
- Show as disabled the option to update expired licenses if the network license is hosted on another machine
- Not show licenses for older versions of a given product
- Not show expired trial licenses
- “Remember my choice” option. By clicking on this option the user won’t need to select the license every time he runs the software, as long as the selected license remains available. If the selected license is not available (e.g. license expired, license in use, unavailable network license, etc.) the user will be prompted again with the license selection screen to choose which license to use.
- On the other hand, if there are no licenses available, this screen will be displayed:
